KMoel.1
Jul 25, 2022 10:24 AM UTC
Does Registers work in STM32Cube Programmer?
I am trying to use Registers in STM32CubeProgrammer to change the setting of GPIOB, but whenever I change a value. it just gets changes back to the value it had before! Is this because Registers is still in BETA or am I doing something wrong?
KMoel.1
KMoel.1Best answer
Jul 25, 2022 1:01 PM UTC
I changed to an other target HW and now it works, so it must have been an issue with the HW. Thank for the help
KnarfB
Jul 25, 2022 11:57 AM UTC
Works for me. Did you press Aplly between Write and Read?
hth
KnarfB
KMoel.1
KMoel.1Author
Jul 25, 2022 11:59 AM UTC
It is when I press Apply that the value changes back to the original value
Andrew Neil
Jul 25, 2022 12:07 PM UTC
What chip?
Which register(s) have you tried?
KMoel.1
KMoel.1Author
Jul 25, 2022 12:10 PM UTC
STM32L476
GPIO8 MODER8, OT8, ODR8
Jul 25, 2022 12:11 PM UTC
Present details of the chip you're using.
Go over the exact sequence you're using.
Make sure clocks are suitably enabled, otherwise peripheral registers will stick at zero
KMoel.1
KMoel.1AuthorBest answer
Andrew Neil
Jul 25, 2022 1:44 PM UTC
If your issue is now resolved, please mark the solution:
