Nov 3, 2025 1:08 PM UTC
Disable Programmer Popups / prompts
Hey there,
Is there an option to turn off the prompts after programming in the STM32CubeProgrammer?
The Log output is enough for me:
Not really a problem, more like a QoL thingy - but i didn't see an option anywhere.
Would be a nice addition if it's currently not present. Like "only prompt on errors"
Aziz BRIGUI
Aziz BRIGUIBest answer
Nov 4, 2025 1:23 PM UTC
Hello @Proxi,
This request is already tracked internally (Internal tracking number: 195238).
In the meantime, you can use the CLI to work around needing to close the pop-ups. Will make sure to give you the update when this is implemented.
Aziz
Aziz BRIGUI
Hello @Proxi,
Aziz
ProxiAuthor
Nov 4, 2025 1:26 PM UTC
Great, thanks for letting me know!
That would be much appreciated!
