Ezgi
May 25, 2021 1:09 PM UTC
connect the cube programmer
I'm programming my custom board using j-link. I want to use cube programmer but I can't connect. What should I do?
May 25, 2021 1:30 PM UTC
Verify your schematic. Ensure power rails are good. Verify chip orientation. Use a different cable. Use a different board. Reboot. Post the actual error.
May 25, 2021 2:03 PM UTC
Cube Programmer is for ST-LINK, not Segger J-Link.
Use appropriate tools.
Ezgi
EzgiAuthor
May 25, 2021 2:07 PM UTC
I want to read data from my external flash. So that I was writing an external loader for cube programmer. If then, what should I do? Could you suggest anything?
