RobNeWin
May 5, 2023 8:12 PM UTC
CLI.exe unsure on how to run this...
Hi there, I'm starting to use the stm32cubeprogrammer sw, and don't know how to practice sending valid commands through this interface. I have located the CLI.exe but every time I click on it, the program executes and then closes. What am i doing wrong?
Peter BENSCH
May 8, 2023 9:45 AM UTC
Welcome, @RobNeWin​, to the community!
you didn't start the GUI but the CLI, which is a Command-Line Interface. As a CLI, it expects commands, either manually from the command line, or from a script file, to be executed.
You can find more information on how to use the GUI or CLI in UM2237.
Hope that helps?
Good luck!
/Peter
