Dalhe.1
May 20, 2021 10:53 AM UTC
Cann't open STM32_Programmer_CLI.exe
I have installed STM32CubeProgrammer 2.7.0 on Windows 10 and it works fine. but when iam trying to run STM32_Programmer_CLI.exe even as admin it open and close immediately. the same thing happens by openning the STM32Bootloader.bat
Could anyone tell me please how to solve this problem?
Depo
Houda GHABRI
Houda GHABRIBest answer
May 24, 2021 9:45 AM UTC
Hi @Dalhe.1​ ,
It seems to be admin right issue in your side, using GUI you face the same problem?
Can you please try to unistalll CubeProgrammer , clean you environment and install it again with admin rights?
Houda
May 20, 2021 12:25 PM UTC
It's a command line interface. Run it from the command prompt. You use it by providing command line arguments, after which it runs and exits when complete.
If you're looking for the GUI, run STM32CubeProgrammer.exe.
Houda GHABRI
May 21, 2021 10:29 AM UTC
Hi @Dalhe.1​ ,
As said by @TDK​ , to use STM32_Programmer_CLI.exe you need to the CLI from CMD:
  • Open CMD
  • Go to bin folder under CubeProgrammer installer folder
  • Launch command according to your configuration for example : STM32_Programmer_CLI.exe -c port=SWD -d file.bin 0x08000000 -v
For more details of CLI usage you can use refer to CubeProgrammer user manual or use this command to have all commands options :
  • STM32_Programmer_CLI.exe --help
If your question is answered, please close this topic by choosing Select as Best. This will help other users find that answer faster.
Houda
Dalhe.1
Dalhe.1Author
May 21, 2021 10:48 AM UTC
Thanks for your answer. i have already did this but i got this error as you can see0693W00000APAeLQAX.png0693W00000APAeMQAX.png
Houda GHABRI
May 21, 2021 11:03 AM UTC
Hi @Dalhe.1​
Can you please copy the STM32CubeProgrammer folder under any user folder (Desktop for example) and try again?
Houda
Dalhe.1
Dalhe.1Author
May 21, 2021 11:11 AM UTC
Hi @Houda GHABRI​
I have just tried and it's always the same error.
Houda GHABRI
Hi @Dalhe.1​ ,
Houda
Dalhe.1
Dalhe.1Author
May 24, 2021 10:34 AM UTC
/Hi @Houda GHABRI​
Many Thnx ... i just did as you said and it finnally worked !!
Houda GHABRI
May 24, 2021 10:42 AM UTC
Hi @Dalhe.1​
Glad to hear that is is finally worked for you :) .
Houda
