DMoim.1
Nov 13, 2024 3:14 PM UTC
Can't program 128bit data in STM32U5 OTP area with Programmer 2.17.0
I've tried to program OTP area of STM32U575 at address 0x0BFA0010 with a quad-word (4x32bit of data) but only half are programmed (the first half) while the 2 remaining words are at 0xFFFFFFFF (erased state) and cannot be programmed anymore.
I've loaded a binary file with 128bits of data, chose the download attress at 0x0BFA0010 and pushed the download button.
Accoding to the datasheet the flash must be programmed 128bit at once: is that implemented in the programmer?
Best regards,
 Diego
Nov 13, 2024 6:24 PM UTC
Hello @DMoim.1
I'm checking internally this issue (tracked via internal ticket: 196262)
We will keep you updated here when progress is made in this request.
Thank you for your contribution.
Nov 14, 2024 10:56 AM UTC
Hi @DMoim.1
Issue is confirmed and our Dev team are working to resolve it.
In the meantime, you can try using Cubeprogrammer version 2.15.0.
Maryem
Mar 7, 2025 11:45 AM UTC
Hello @DMoim.1 ,
The issue has been fixed in STM32CubeProgrammer v2.19.0
You can download it from this Link.
Maryem.
