Nov 27, 2024 5:07 PM UTC
After upgrade to CubeProgrammer 2.18.0 cannot run programmer
Tried to remove and install previous version
Still have error, linux
Linux namee 6.11.0-107009-tuxedo #9tuxnoble1 SMP PREEMPT_DYNAMIC Fri Nov  8 19:23:20 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
kubuntu 24.04 lts based
2024-11-27 15:03:10,758 JavaFX Application Thread ERROR Unable to locate appender "csvFile" for logger config "com.st.mtt"
Loading PRG Library: /home/username/STMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/../lib/libCubeProgrammer_API.so
[Analytics] No requests are done with CLI
Could not load Config.fxml
javafx.fxml.LoadException:
file:/home/usernameSTMicroelectronics/STM32Cube/STM32CubeProgrammer/bin/STM32CubeProgrammerLauncher!/fxml/Config.fxml
       at javafx.fxml.FXMLLoader.constructLoadException(FXMLLoader.java:2608)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2586)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2448)
       at javafx.fxml.FXMLLoader.load(FXMLLoader.java:2416)
       at com.st.controllers.MainWindowController.initialize(MainWindowController.java:1304)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2555)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3251)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3212)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3185)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3161)
       at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3141)
       at javafx.fxml.FXMLLoader.load(FXMLLoader.java:3134)
       at com.st.app.Main.openCubeProgrammmerWindow(Main.java:192)
       at com.st.app.Main.start(Main.java:184)
       at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$8(LauncherImpl.java:769)
       at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$7(PlatformImpl.java:326)
       at com.sun.javafx.application.PlatformImpl.lambda$null$5(PlatformImpl.java:295)
       at java.security.AccessController.doPrivileged(Native Method)
       at com.sun.javafx.application.PlatformImpl.lambda$runLater$6(PlatformImpl.java:294)
       at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:95)
       at com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
       at com.sun.glass.ui.gtk.GtkApplication.lambda$null$10(GtkApplication.java:245)
       at java.lang.Thread.run(Thread.java:750)
Caused by: java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
       at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1774)
       at javafx.fxml.FXMLLoader$ControllerMethodEventHandler.handle(FXMLLoader.java:1657)
       at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
       at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238)
       at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
       at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
       at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
       at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
       at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
       at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
       at javafx.event.Event.fireEvent(Event.java:198)
       at javafx.scene.Node.fireEvent(Node.java:8411)
       at javafx.scene.control.Button.fire(Button.java:185)
       at com.st.controllers.ConfigController.refreshAllInterfaces(ConfigController.java:1186)
       at com.st.controllers.ConfigController.initialize(ConfigController.java:484)
       ... 22 more
Caused by: java.lang.reflect.InvocationTargetException
       at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
       at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
       at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
       at java.lang.reflect.Method.invoke(Method.java:498)
       at sun.reflect.misc.Trampoline.invoke(MethodUtil.java:72)
       at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
       at sun.reflect.misc.MethodUtil.invoke(MethodUtil.java:276)
       at javafx.fxml.FXMLLoader$MethodHandler.invoke(FXMLLoader.java:1769)
       ... 37 more
       at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49)
       at com.st.controllers.ConfigController.refresh(ConfigController.java:968)
       at com.st.controllers.ConfigController.refreshSTLink(ConfigController.java:996)
       ... 47 more
       ... 59 more
       at com.st.controllers.ConfigController.selectProbe(ConfigController.java:810)
       ... 69 more
       ... 80 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
       at com.st.controllers.ConfigController.selectPort(ConfigController.java:742)
       ... 90 more
Exception in Application start method
       at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:382)
       at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:321)
       at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:893)
Caused by: java.lang.RuntimeException: Exception in Application start method
       at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:823)
       at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$1(LauncherImpl.java:181)
Caused by: java.lang.NullPointerException
       at com.sun.javafx.scene.control.skin.SplitPaneSkin$Content.computeMaxWidth(SplitPaneSkin.java:1165)
       at javafx.scene.layout.Region.maxWidth(Region.java:1451)
       at com.sun.javafx.scene.control.skin.SplitPaneSkin.layoutChildren(SplitPaneSkin.java:705)
       at javafx.scene.control.Control.layoutChildren(Control.java:578)
       at javafx.scene.Parent.layout(Parent.java:1087)
       at javafx.scene.Parent.layout(Parent.java:1093)
       at javafx.scene.Scene.doLayoutPass(Scene.java:552)
       at javafx.scene.Scene.preferredSize(Scene.java:1649)
       at javafx.scene.Scene.impl_preferredSize(Scene.java:1723)
       at javafx.stage.Window$9.invalidated(Window.java:889)
       at javafx.beans.property.BooleanPropertyBase.markInvalid(BooleanPropertyBase.java:109)
       at javafx.beans.property.BooleanPropertyBase.set(BooleanPropertyBase.java:144)
       at javafx.stage.Window.setShowing(Window.java:965)
       at javafx.stage.Window.show(Window.java:980)
       at javafx.stage.Stage.show(Stage.java:263)
       at com.st.app.Main.openCubeProgrammmerWindow(Main.java:524)
       ... 1 more
Exception running application com.st.app.Main
Aziz BRIGUI
Aziz BRIGUIBest answer
Nov 28, 2024 8:58 AM UTC
Hello @AndriiGalinovskyi
We apologize for the inconvenience, but kubuntu doesn't figure in the list of supported OS mentioned in UM2237 page 12. I suggest if you're using STM32CubeProgrammer to switch to any of the linux distributions listed in the user manual.
I just tried doing the update from v2.17 to v2.18 in ubuntu 24.04.1 and it works just fine.
Aziz
Aziz BRIGUI
Aziz
Dec 5, 2024 11:23 AM UTC
The problem appeared after new system updates and disappeared the next day after the next updates. I lost a day trying to solve it, but now everything works again. Thanks
