Jul 24, 2026 00:53 UTC
STM32CubeMX2: Limited export capabilities
Missing Makefile export capability. Missing option to export only minimum necessary files. Unfortunately this leads to bloated projects. The previous version of STM32CubeMX have these features. Clean and self-contain and not bloated project was the main reason to use STM32 in our company.
MorkBeck
MorkBeckBest answer
Aug 20, 2026 07:10 UTC
Thanks for the feedback!
Exporting only the files your configuration actually uses is on the roadmap.
Today the full pack gets copied in, which is exactly the bloat you're
describing. No release date to give you yet.
Makefile export as its own target isn't on the roadmap. The direction is CMake,
and from a generated CMake project you can get a Makefile build:
    cmake -B build -G "Unix Makefiles" -DCMAKE_TOOLCHAIN_FILE=<toolchain>
    cmake --build build
Not identical to what you had, but it works today.
Mads
CubeMX2 Product Marketing
Amel NASRI
Aug 18, 2026 14:59 UTC
Moved from Introducing STM32CubeMX2, a new flavor of STM32CubeMX tool for tracking and follow-up purposes.
MorkBeck
MorkBeckBest answer
    cmake --build build
Mads
