MorkBeck
Nov 18, 2026 8:15 AM UTC
Hi Andrew!
Thanks, for STM32C5, this is already available through the online STM32 Example Library.
Filter by STM32C5 and choose an example marked STM32CubeMX2 in the Configurable column. Use Select IDE to choose the project format. Download and extract the example, then import its .ioc2 file into MX2.
The online library is the intended entry point. We do not plan a separate “Start from example” button inside MX2.
Andrew Neil
Nov 18, 2026 9:38 AM UTC
Well, no - my point is that’s not like having the ‘Start from example’ button which MX1 has.
It is an added friction point not found in MX1.
Especially as the Example Library link is not always visible in MX2:
Oh well - fair enough.
Andrew Neil
Nov 18, 2026 9:43 AM UTC
To expand on that:
MX1 MX2
  1. Open MX1
  2. Choose the example
  3. You’re done!
  1. Open Example library
  2. Choose example
  3. Download example
  4. Unzip example
  5. Open example in MX2
