gil_dobjanschi
Senior
Apr 23, 2026 18:09 UTC
Make Decimal/Hex display of values selectable (and sticky)
I used MX2 for the last two weeks and it is a great improvement over MX. I build many small projects with it and I am constantly running into a problem related to timer configuration. I enter the values for the Prescaler and the Counter period as Integers and unfortunately when I close the project and reopen MX2 converts the value to Hex (and indicates that it is a Hex value). I keep forgetting that MX2 does this and I enter a new value as an Int thinking that my selection was sticky. Could you make the Int/Hex selection sticky? It's a small issue but it will save developers some trouble.
Thank you,
Gil
MorkBeck
Apr 24, 2026 07:30 UTC
Hello @gil_dobjanschi ,
Love this feedback, and thanks for calling it out.
You are right, the Int/Hex choice should stay where you left it when you reopen a project. That would avoid exactly the kind of small, repeated mistake you described.
We will add it to the list of UX Improvements!
Thank you,
Mads
