gil_dobjanschi
Senior
May 4, 2026 11:09 UTC
Is CMSIS-RTOS2 code generation supported in MX2?
Is there a way to generate code with MX2 by using the CMSIS-RTOS2 API vs the FreeRTOS API? I cannot find a setting in the FreeRTOS configuration to specify that I would like to use the CMSIS-RTOS2 API.
Thank you,
-GIl
Khaled_DHIFBest answer
May 5, 2026 10:05 UTC
Hello @gil_dobjanschi ,
No. In the current STM32CubeMX2 flow for STM32C5, code generation exposes the native FreeRTOS kernel API directly and does not provide a CMSIS-RTOS2 abstraction layer. That’s why there is no setting to select CMSIS-RTOS2 in the FreeRTOS configuration.
Kind regards,
DHIF Khaled
"Please mark my answer as best by clicking on the “Accept as solution"" button if it fully answered your question. This will help other users find this solution faster.​"
Kind regards,
DHIF Khaled
Andrew Neil
May 5, 2026 10:46 UTC
As @Khaled_DHIF said, ST do not provide this.
But FreeRTOS is an independent, 3rd-party product - so there's nothing to stop you doing it yourself.
eg, see: Where to find if specific STM32 MCU supports specific CMSIS-RTOS version?
gil_dobjanschi
Senior
May 5, 2026 12:25 UTC
Thank you @Khaled_DHIF and @Andrew Neil !
Pavel A.
May 5, 2026 14:15 UTC
Option to generate for CMSIS-RTOS can be interesting, especially for education users.
Some people already tried to fiddle the generation templates. Maybe it still is possible with MX2.
If not - perhaps the usual AI coding things can be tasked to convert FreeRTOS code to CMSIS-RTOS?
gil_dobjanschi
Senior
May 6, 2026 04:58 UTC
Hi @Pavel A.
For what is worth I ended up using FreeRTOS API. In my case the benefit to have the API mapping wasn't that great because I do not expect users to switch RTOS. Additionally, I am using xQueueCreateSet which I could not map to an API in CMSIS-RTOS2 as far as I can tell.
Your suggestion to use AI to generate the code is a viable one. I used Claude to generate the code and it looks reasonable. I did not look at it in detail but with a bit of determination it can be done. One just needs the clear motivation.
Regards,
-GIl
