Cubemx2 Scroll to zoom
On cubemx I could use the scroll wheel to pan and zoom, a brilliant feature which has been removed in mx2, can we have it reinstated as the app is very frustrating to use without it
MorkBeck
Hi sdobbie2,
Thanks for raising this, feedback like yours is genuinely useful to us, and this one lands. Scroll-wheel pan and zoom is something we are improving in CubeMX2. Navigation in the views is not where we want it yet, and your report adds weight to that.
I can't give you a version or a date today, and I'd rather not promise one I can't hold. What I can do is make sure this is logged against the work already under way, and come back here once there is something concrete for you to try.
One thing that would help us: which view hurts most, the pinout, the clock tree, or the configuration panels?
Mads, Marketing Manager for CubeMX2
sdobbie2Author
It’s all three. If you look at the old cubemx, it was easy to use, I could just right click a pin and assign a label. Revert back to the exact same UI experience of the old cubemx would be my solution. If something works, don’t break it.
As a sidenote, if you are using AI to respond to people, please don’t.
