av500
CubeMX2: generated cmake files state version 3.20, but in fact version 3.30 is needed
when generating cmake file from CubeMX2, CMakeLists.txt states:
cmake_minimum_required(VERSION 3.20)
but in fact you need a minimum version of 3.3:
Saket_OmBest answer
Hello ​@av500
This issue is resolved starting from STM32CubeMX version 1.1.0.
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
Hello @av500
Thank you for bringing this issue to our attention.
I reported this internally.
Internal ticket number: CDM0060487
Hello @av500
The issue is caused by the following lines in stm32c5xx_dfp/CMakeLists.txt:
# Include RTE_Components.h globally if needed
if(CMSIS_Tcompiler STREQUAL "IAR")
 target_compile_options(STMicroelectronics_stm32c5xx_dfp_2_0_0 INTERFACE "SHELL:--preinclude $<QUOTE>${CMAKE_CURRENT_LIST_DIR}/RTE_Components.h$<QUOTE>")
else()
 target_compile_options(STMicroelectronics_stm32c5xx_dfp_2_0_0 INTERFACE "SHELL:-include $<QUOTE>${CMAKE_CURRENT_LIST_DIR}/RTE_Components.h$<QUOTE>")
endif()
It can be fixed quite simply by changing the lines slightly to use an escaped quote (\") instead of <QUOTE>. This keeps compatibility with older versions:
 target_compile_options(STMicroelectronics_stm32c5xx_dfp_2_0_0 INTERFACE "SHELL:--preinclude \"${CMAKE_CURRENT_LIST_DIR}/RTE_Components.h\"")
else()
 target_compile_options(STMicroelectronics_stm32c5xx_dfp_2_0_0 INTERFACE "SHELL:-include \"${CMAKE_CURRENT_LIST_DIR}/RTE_Components.h\"")
endif()
Saket_OmBest answer
Hello ​@av500
