Ashja .S
May 25, 2022 3:00 PM UTC
X-CUBE-IRREMOTE for stm32g030f6p6
 Hey,
I am trying to include X-CUBE-IRREMOTE for stm32g030f6p6 but it doesnt show up in software packs in cubeMX
if i try to manually install it it gives an error of invalid packet
Peter BENSCH
Peter BENSCHBest answer
May 25, 2022 3:09 PM UTC
The core of the question relates to the same cause as has been discussed before in the community. At that time it was about X-CUBE-EEPROM, but the principle is the same.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
Ashja .S
Ashja .SAuthor
May 25, 2022 3:12 PM UTC
hey @Peter BENSCH​ ,
Thanks for the promt reply.So i can use the drivers inside this X-CUBE-IRREMOTE and use them ?
Peter BENSCH
May 25, 2022 5:25 PM UTC
Yes, you can directly use them.
