gerhard
Jul 4, 2020 12:00 AM UTC
X-CUBE-BLE1 BlueNRG-MS - does not generate BLE app app_x-cube-ble1.c
STM32CubeMX 5.6.1 does not generate the Application app_x-cube-ble1.c so the initialization is also missing in main.c
Is there a fix for this?
gerhard
gerhardAuthor
Jul 4, 2020 2:16 PM UTC
Fixed - with STM32CubeMX 5.40
I tried older versions of CubeMX, and STM32CubeMX 5.40 does generate the Application app_x-cube-ble1.c file and the initialisation in main.c: MX_BlueNRG_MS_Iinit()
I hope ST fixes this in the latest STM32CubeMX
Khouloud ZEMMELI
Jul 6, 2020 10:58 AM UTC
​Hi @gerhard​
could you please share your ioc file?
Khouloud
gerhard
gerhardAuthor
Jul 6, 2020 12:41 PM UTC
Khouloud,
I included the pdf Report as well..
0_GettingStarted_561.zip
0_GettingStarted_540.zip
Any help appreciated
gerhard
gerhardAuthor
Jul 6, 2020 12:42 PM UTC
Khouloud ZEMMELI
Jul 6, 2020 12:46 PM UTC
Thanks @gerhard​ , well it's not a bug , ​In the new version , the "app_x-cube-ble1.c" has been replaced with "app_bluenrg_ms.c" , and you will find the #include "app_bluenrg_ms.h" in main.c
Best Regards,
Khouloud
gerhard
gerhardAuthor
Jul 6, 2020 1:08 PM UTC
Khouloud,
Unfortunately this is not the case.
app_x-cube-ble1.c does not get generated
#include "app_bluenrg_ms.h" is also NOT in main.c
I generate the CubeMX project in the same way with 5.6.1 and 5.4.0.
I tried this many times.
PS.
I noticed that sys.c and sys.h is also not generated, even thous it was set up in CubeMX
Khouloud ZEMMELI
Jul 6, 2020 1:29 PM UTC
​Hi @gerhard​
You need to  select an application under Device in the pack to optain "app_bluenrg_ms.c".
For the sys.c/h it was a bug in 5.4.0 and now fixed (they should not be generated).
Best Rgerads,
Khouloud
