MStra.3
May 17, 2021 11:40 PM UTC
Why is CubeMX trying to enable Overclocking in my project?
I created a new project for an STM32F407VE and when the code is generated CubeMX puts this in SystemClock_Config:
 /** Activate the Over-Drive mode
 if (HAL_PWREx_EnableOverDrive() != HAL_OK)
  Error_Handler();
When you try to compile it, it gets an error because HAL_PWREx_EnableOverDrive() is not defined!
The whole SystemClock_Config is here:
void SystemClock_Config(void)
 __HAL_RCC_PWR_CLK_ENABLE();
 __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
 RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
 RCC_OscInitStruct.HSEState = RCC_HSE_ON;
 RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
 RCC_OscInitStruct.PLL.PLLM = 25;
 RCC_OscInitStruct.PLL.PLLN = 336;
 RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
 RCC_OscInitStruct.PLL.PLLQ = 4;
  Error_Handler();
  Error_Handler();
 RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
 RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
 if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
  Error_Handler();
Mike.
TDKBest answer
May 17, 2021 11:53 PM UTC
Overdrive mode is required for speeds above 168 MHz. It's not overclocking. In any case, it's not available on the F407 so generated code shouldn't have it.
I couldn't reproduce this on a new project. Attach your IOC if you can.
Here's what CubeMX spat out for me:
 * @retval None
 Error_Handler();
 Error_Handler();
TDKBest answer
 * @retval None
 Error_Handler();
 Error_Handler();
MStra.3
MStra.3Author
May 17, 2021 11:58 PM UTC
Here is the IOC file.
