JLee.0
Nov 26, 2018 2:36 AM UTC
Why does Keil run crash when debugging with KEIL project generated by STM32CubeMX 5.0?
Jeroen3
Senior
Nov 26, 2018 8:02 AM UTC
Make sure you only use ASCII in paths and files.
http://www.keil.com/support/docs/4036.htm
Otherwise report the bug to keil.
JLee.0
JLee.0Author
Nov 26, 2018 8:13 AM UTC
Thank you for your answer.
but The source files for my entire project are all generated by STM32CubeMX 5.0, I have not added any source files.
