Peko
Nov 16, 2018 2:13 PM UTC
Why CubeMx doesn't support DP83848 in RMII mode ?
I need create UDP server on STM32F407 with PHY DP83848 in RMII mode. I started with CubeMx, but it support only LAN8720 in this mode.
What is the solution?
Thank you.
Peter
Nawres GHARBI
Nov 19, 2018 8:37 AM UTC
Hi @Peko​
Thanks for the feedback it will be fixed for the 5.1.0
Peko
PekoAuthor
Nov 20, 2018 8:09 AM UTC
the actual version is 4.27. When you plan to release version 5.1.0 ?
What are the differences between LAN8720 and DP83848 in RMII mode?
Peter
