РПосл.1
Aug 20, 2021 10:10 AM UTC
Why CubeMx cannot generate code only with CMSIS without HAL,LL? It would be very cool for the Stm32CubeMx to generate code using only CMSIS lib.
Peter BENSCH
Aug 20, 2021 10:59 AM UTC
CMSIS only relates to the core, while HAL and LL also support the peripherals.
/Peter
РПосл.1
Aug 20, 2021 11:07 AM UTC
If I'm not mistaken cmsis describes not only Core. This library have structures for describe peripheral s Pozdrawiam, Raman Pasledni On 20 Aug 2021, 12:59 +0200, ST Community , wrote: CMSIS only relates to the core, while HAL and LL also support the peripherals. Regards /Peter [https://community.st.com/ncsphoto/UINeD2JN0zF5cg_LIZ7Z1WX9ZeweZNqxdzQxrFlQ4OQQwIAouzw-VWNYyB8EUVFR?fromEmail=1]<> Peter BENSCH<> (ST Employee) CMSIS only relates to the core, while HAL and LL also support the peripherals. Regards /Peter View/Answer<> or reply to this email Replying to [https://community.st.com/img/userprofile/default_profile_45_v2.png?fromEmail=1]<> РПо�?л.1<> (Community Member) asked a question. Friday, August 20, 2021 3:10 AM<> Why CubeMx cannot generate code only with CMSIS without HAL,LL? It would be very cool for the Stm32CubeMx to generate code using only CMSIS lib. [https://community.st.com/ncsphoto/UINeD2JN0zF5cg_LIZ7Z1WX9ZeweZNqxdzQxrFlQ4OQQwIAouzw-VWNYyB8EUVFR?fromEmail=1]<> Peter BENSCH<> (ST Employee) CMSIS only relates to the core, while HAL and LL also support the peripherals. Regards /Peter Friday, August 20, 2021 3:59 AM<> You're receiving emails when someone "Comments on my posts." To change or turn off ST Community email, log in<> as rpasledni@ibib.waw.pl.st. Are notifications about this post getting annoying? Reply to this email with the word " mute ". STMicroelectronics N.V. [ST Community]
Peter BENSCH
Aug 20, 2021 12:19 PM UTC
Well, beside the core it also covers some serial communication and memory interfaces - but no analog peripheral, like adc, dac, comparators, opamps, temp sensor, no crypto management, no watchdog, lcd, rtc and timers.
Does it really make sense to create a program exclusively on CMSIS and not to support the other peripherals?
BTW: please do not reply by email as this creates a lot of garbage in the thread.
/Peter
