MBale.1
Jan 4, 2022 5:38 AM UTC
When I try to generate user code through CubeMX 6.4.0, the program hangs. If I try to update user code from a demo project, the program doesn't hang. Why?
Jan 4, 2022 3:08 PM UTC
There is not enough detail in this question to provide an informed response. Probably one program has bugs while the other may not. Diff the source files.
Sara BEN HADJ YAHYA
Jan 6, 2022 12:52 PM UTC
Hello @MBale.1​ ,
Thanks for your feedback,
Could you please share your .ioc file and specify which demo are you using?
Thanks,
Sara.
MBale.1
MBale.1Author
Jan 8, 2022 9:19 PM UTC
The demo I am using is called "Six-Step Sensorless and Voltage Mode on a STEVAL-SPIN3204+Shinano LA052-800"
Sara BEN HADJ YAHYA
Jan 10, 2022 8:24 AM UTC
Hello @MBale.1​ ,
Could you please provide us with more details, does your code disappear when you regenerate your code, is that your issue?
Sara.
MBale.1
MBale.1Author
Jan 12, 2022 4:58 PM UTC
Here are my issues:
  1. When I create a new project and press "Generate", CubeMX gets stuck and does nothing.
  2. When I try to open any of the demo projects and press "Update", CubeMX also gets stuck and does nothing
This is using ST Motor Control Workbench 5.Y.3 with CubeMX 6.4.0
