ONaor
May 13, 2019 7:55 AM UTC
__weak functions in stm32XXxx_it.c
Is it possible to fix the CubeMX so that when it generates the code for STM32 chips it will add __weak declration to the following functions:
SysTick_Handler
PendSV_Handler
inside stm32XXxx_it.c
While intergrating to embOS, the OS api overrides these function and each time I make an adjustments to the cube it will delete the __weak decleration since there is /* USER CODE BEGIN */ in the prototypes
