VREFBUFF option is not available in CubeMx for STM32G4
Question moved from this post.
Hi @mƎALLEm ,
I am using STMCubeIDE with cubeMX, in that there is no such configuration for VREFBUF. is there any alternative way for that?
mƎALLEm
mƎALLEmBest answer
After checking, VREFBUF option is available under SYS menu.
This thread will be closed.
mƎALLEm
According to the datasheet STM32G491RET6 features an internal voltage reference buffer (VREFBUF)
It seems VREFBUF option is missing in CubeMx. I will escalate internally for analysis and eventual fix in the tool (internal ticket number 225569 for follow-up).
Try to add this code in the User code section (inspired from H7 generated code): scale set to 0 (2.5V)
 /** Configure the internal voltage reference buffer voltage scale
 HAL_SYSCFG_VREFBUF_VoltageScalingConfig(SYSCFG_VREFBUF_VOLTAGE_SCALE0);
 /** Enable the Internal Voltage Reference buffer
 HAL_SYSCFG_EnableVREFBUF();
 /** Configure the internal voltage reference buffer high impedance mode
 HAL_SYSCFG_VREFBUF_HighImpedanceConfig(SYSCFG_VREFBUF_HIGH_IMPEDANCE_DISABLE);
mƎALLEm
mƎALLEmBest answer
