Zhou JianQiang
Senior
Oct 30, 2026 2:20 AM UTC
Using cubeMX 6.18.1, stm32l4p5rg can’t generate audio files
Hi ​;
With cubeMX 6.18.1, stm32l4p5rg still can’t generate audio files.
Can you help confirm this issue?
Oct 30, 2026 10:07 AM UTC
Hello ​@Zhou JianQiang
Thank you for reporting this behavior,
After selecting the component in Software Pack Component, Have you checked USB USBX mode in the Configuration UI?
BR, Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Zhou JianQiang
Senior
Oct 30, 2026 2:53 PM UTC
Hi ​@Souhaib MAZHOUD :
Yes, I have checked usbx mode.
I attached ioc file.
Oct 30, 2026 3:34 PM UTC
Could you please uncheck the "generate under root" option in the Project Manager toolchain and check the generated files again? This is what I got on my side.
Zhou JianQiang
Senior
Nov 4, 2026 12:44 AM UTC
In this folder, it should have some files like below:
Below is from STM32H7 as attachment.
Nov 6, 2026 9:25 AM UTC
This issue has been escalated to dedicated team for further investigation : Internal ticket number: CDM0067225 (This is an internal tracking number and is not accessible or usable by customers.)
Regards,
Souhaib
