Usart1 BRR register seems strange when using STM32H743 with stm32cubeh7 1.12.1
Dear all,
    I have encountered an strange issue. I set Usart1 Baud Rate to 115200, however, Usart1 BRR[15:4]==0x0082, which corresponds to 57600.(57600 == 120Mhz/(16*0x82)).
  I also noticed that HAL_RCC_GetPCLK2Freq() returns a wrong pclk value 0x0E4E1C00(240M), but it should be 120M.
The Usart1 Config and Rcc config are as follows :
TDKBest answer
This has been an issue in the past. Is your STM32H7 package fully updated? If so, can you include your IOC file here?
The relevant fix was made 4 months ago. (Might not be this exact change.)
TDKBest answer
Pavel A.
This line with D1CorePrescalerTable array has not been changed recently.
Pavel A.
Can you compare the generated code, especially for SystemClock_Config?
