alex_embedded
Apr 18, 2019 1:15 AM UTC
Updating fatfs in a project
Hi All,
I have downloaded the latest version of the fatfs library from
http://elm-chan.org/fsw/ff/00index_e.html
I have a project with the fatfs middleware running, the project was created via cubemx. So far I have had no issues with the librabry, however I would like to update to the latest version. Simply copying the files over is causing a long list of errors, not in my code but in the files for the middleware.
How do I find out what version of fatfs I am currently on, and how do I properly update to the latest version?
Thanks all for your time! :D
alex_embedded
Apr 18, 2019 1:17 AM UTC
*UPDATE*
Just found the version that is in cubemx.
I am currently using R0.11, and I want to update to R0.13c
Apr 18, 2019 3:26 AM UTC
The FatFs model changed a bit. You'll have to remove the current source files, replace with the new equivalents, and port the diskio.c layer to match the new model. The configuration file is also different.
You'd want to use the new version for large EXFAT volumes, seen issues here with 200/400 GB cards
diskio.c
diskio.h
ff.c
ff.h
ffconf.h
ffsystem.c
ffunicode.c
integer.h
