Vivek pkd
Mar 15, 2022 11:33 AM UTC
Unknown error during running code on STM32F105R8
Hi all,
I have made a source code that runs fine, But after 6 months I again tried to run the same code. Now the running stuck at some point,
The code stuck at this point is shown below
0693W00000KcfPYQAZ.pngIs this error occur due to any hardware failure like oscillator /capacitor
Anybody, please help???
Mar 15, 2022 12:37 PM UTC
Could be, or invalid clock settings. Put a scope on HSE to see if it's working.
ONadr.1
Senior III
Mar 15, 2022 12:42 PM UTC
The best option is measure (by osciloscope, counter, LA), that external oscilator is working. You can try PLL feed from internal HSI oscilator to check if PLL get ready.
Vivek pkd
Vivek pkdAuthor
Mar 17, 2022 4:11 AM UTC
Thanks.@TDK​  ,@ONadr.1​  , I checked with the Oscilloscope, I found some irregularities across Oscillator. So I replaced Oscillator with new one, The issue solved
