yuri CH
Senior
Apr 27, 2021 12:02 PM UTC
Unable to update sw generated by cubeMX for stm32H747i-Disco.
Examples from the relevant cube repository are working perfectly fine, i am able to burn, run and debug them. when i generate a project using CubeMX (while selecting the right board) i am not able to do so and get the following messsage:
Fatal error: Failed the search for probes, ensure that the USB drivers are installed.
please note that i have tried reinstalling CubeMX and downloading the H7 repository.
please advise on how to resolve this issue.
thanks.
Mouadh JERIDI
Apr 28, 2021 12:21 PM UTC
Hello @yuri CH​
Thank you for your post.
Would you mind please provide me with the exact steps to reproduce this issue ?
Thanks,
Mouadh
yuri CH
yuri CHAuthor
Senior
Apr 28, 2021 2:27 PM UTC
thanks for your response.
ofcourse.
  1. open the cubeMX(6.2.1) of the latest version with the latest version of the H7 repository (1.9.0).
  2. choose the STM32H747i-Disco using the board selector option.
  3. Create a project with default defenitions.
  4. Generate project by those default defenitions.
  5. Open the project, Download and debug each of the cores using IAR embedded workbench IDE.
step 5 fails and the IDE pops a message which says : Fatal error: Failed the search for probes, ensure that the USB drivers are installed. Session aborted!
