Apr 1, 2024 5:16 AM UTC
to run the code in keil
I created a project based on stm32h743 ,ARM M7 in keil through cubeMX, so my problem is, i need to run the code in debug ,for that i need to press the run button  3 times , then only my code execution is starting ,otherwise it does not , so please provide me a solution to runs the code execution when i press run button only one time  .
thank you,,,,,
