TBell.2
Apr 13, 2022 12:49 PM UTC
SystemClock_Config fails at startup after upgrading CubeMX app
I seem to be having an issue on my custom board. I upgraded my CubeMX app and now when I attempt to debug the application fails when HAL_RCC_OscConfig is called in method SystemClock_Config at startup. It's consistent every time. I've scoured the configuration files to no avail.
Apr 13, 2022 1:16 PM UTC
Step through the code, where does it fail within HAL_RCC_OscConfig?
TBell.2
TBell.2Author
Apr 13, 2022 1:18 PM UTC
tickstart = HAL_GetTick();
Line 501
TBell.2
TBell.2Author
Apr 13, 2022 1:19 PM UTC
It reports a bus fault
TBell.2
TBell.2Author
Apr 13, 2022 1:34 PM UTC
If I click reset on the debugger and hit go it gets past this line every time
TBell.2
TBell.2Author
Apr 13, 2022 1:36 PM UTC
And, when it runs the software timers don't work at all.
Apr 13, 2022 1:38 PM UTC
Perhaps the clock source is unstable or not at the frequency you're expecting. HAL_GetTick is harmless, examine the code yourself.
TBell.2
TBell.2Author
Apr 13, 2022 1:39 PM UTC
The clock is internal PLL
TBell.2
TBell.2Author
Apr 13, 2022 1:53 PM UTC
When I updated the CubeMX and the port files this started happening
