Support for MDK-ARM version 6.6 in STM32CubeMx
Hi Team,
Please help add support for MDK-ARM version 6.22. Currently highest selectable Min Version is V5.32
Thanks in advance.
jumman_JHINGA
Senior III
no issue .... you can generate your project in 5.32 and you can open it in the higher version of MDK-ARM
When I generate a project using 5.32 version and compile it in Keil IDE. I am getting errors as below. Attached a document which has the errors.
jumman_JHINGA
Senior III
in the code generation select ARM Compiler option as "Use Default Compiler version 5". after doing this if you'll get same errors then you need to download version 5 compiler from keil website.
I can compile using version 5, but I need help building an example for compiler version 6.
Any update on my query?
jumman_JHINGA
Senior III
hii @SupriyaChakilam , sorry for late replay.. This artical converting-keil5-project-to-keil6 might help you to do your task. it is explained for TouchGFX but you can ignore TouchGFX related steps and focus on keil compiler settings.
