Mar 31, 2018 10:54 PM UTC
STMCube MX STM32L053 LPUART pin settings bug
Posted on April 01, 2018 at 00:54
I just faced a problem in STMCube MX for STM32L053R8T6, there is no option to select alternative function OPEN DRAIN output for LPUART1.
I see the option for USART1 or USART2 GPIO settings but not for LPUART1.
I First thought that option is not available for LPUART peripheral, so checked all datasheet's related pages ... but didn't find any note about it.
Finally i changed the generated code (LPUART1 MspInit part) manually and set the TX pin of LPUART1 output mode to GPIO_MODE_AF_OD, then it worked.
I just wanted to inform you to correct this bug in the software for future.
The Installed package for L0 series in STMCube is V1.10.0 (The last update).
Thanks & Regards.
#push-pull-output-or-open-drain-output #lpuart #stmcube-mx #stm32l0-lpuart-output-mode
Apr 2, 2018 3:09 PM UTC
Posted on April 02, 2018 at 17:09
Hello
fallah.omid
Thank you for your reported issue.This is highlighted internally to CubeMx team.
Best Regards,
Imen
