WKUNY.1
Jan 22, 2020 1:53 PM UTC
Stm427 uses CUBE MX to generate LWIP code
Stm427 uses CUBE MX to generate LWIP code, if define MEM_USE_POOLS 1 compile error, how to solve?
Nesrine.JLASSI
Jan 24, 2020 4:25 PM UTC
Hello @WKUNY.1​
Thanks for the feedback, it will be fixed next CubeMX version.
Best regards,
Nesrine
Nesrine.JLASSI
Jan 27, 2020 10:22 AM UTC
Hello @WKUNY.1​
If you read the Description of MEM_USE_POOLS parameter, an important Warning needs to be considered: "Warning: if you enable both MEMP_USE_CUSTOM_POOLS and MEM_USE_POOLS, you must have lwippools.h in your include path somewhere and you must define your pools within lwippools.h".
Therefore, by commenting the code in USER SECTION 0 within lwippools.h (this define default pools), you will get rid off this error.
Best regards,
Nesrine
WKUNY.1
WKUNY.1Author
Jan 27, 2020 10:48 AM UTC
Thank you very much! I'll try it.
