STM32N645Z0 Ethernet Configuration Support in STM32CubeMX
I am currently evaluating the
for use with 1000Base-T Ethernet and am attempting to configure the peripherals using STM32CubeMX. While following the same process as with other STM32 chips, I was unable to find the Ethernet configuration under Pinout & Configuration -> Connectivity. Could you kindly advise where I should configure the Ethernet settings?
Thank you for your assistance.
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello @modecs
Thank you for your contribution.
ETH should be available for STM32N645Z0, according to*DS14791 Rev. 9, Table 18, which indicates Ethernet signal support for the VFBGA142 package.
For RMII mode, the supported signals are
ETH1_MDC on B12, ETH1_MDIO on K1, ETH1_CLK on K3, ETH1_RMII_REF_CLK on M2, ETH1_RMII_CRS_DV on K2, ETH1_RMII_TX_EN on N2, ETH1_RMII_TXD0 on P1, ETH1_RMII_TXD1 on N3, ETH1_RMII_RXD0 on L2, and ETH1_RMII_RXD1 on M1.
A ticket #0062266  has been escalated to the development team to investigate and correct this behavior.
I will keep you posted with updates.
THX
Ghofrane
Ghofrane GSOURI
Hello @modecs
THX
Ghofrane
Ghofrane GSOURI
Hello ​@modecs
This issue has been fixed in the latest version of STM32CubeMX 6.18.0
Download STM32CubeMX6.18.0 from  here
THX
Ghofrane
