lukin
Oct 1, 2022 10:52 PM UTC
STM32L4R9 in Low Power Stop mode with FreeRTOS
has anyone a good code example for Stop Mode with FreeRTOS?
I am using CubeMx but it seems the vPortSuppressTicksAndSleep function needs to be modified.
Thank you
MM..1
Oct 2, 2022 9:41 AM UTC
lukin
lukinAuthor
Oct 3, 2022 10:06 AM UTC
Hi checked already. Since I am generating code with CubeIDE, the example requires to modify some freertos code. So, everytime I generate code for any modification, I loose the freertos modifications.
Is there any solution?
