Sep 14, 2026 20:04 UTC
STM32L496 MSI autocalibration in CubeMX
I am trying to configure the clock for the STM32L496 microcontroller, as shown in the screenshot below.
I would like to use MSI in PLL mode with the LSE. When I configure the LSE in CubeMX, the 'MSI Auto Calibration' option disappears. When the LSE is disabled, the option is visible, but it cannot be enabled.
Please tell me how to correctly configure MSI in PLL mode with the LSE in CubeMX.
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Sep 16, 2026 10:54 UTC
Hello ​@MirKoz2 ​@gbm
Thank you all for your contribution.
Issue has been escalated to dev team under internal ticket ID #0065803
I will keep you posted with updates.
THX
Ghofrane
gbm
Sep 15, 2026 13:13 UTC
Just checked with the current CubeMX (6.18.1) and I am unable to reproduce the problem - everything works as intended.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
MirKoz2Author
Sep 16, 2026 06:50 UTC
I did it in the current CubeMX (6.18.1).
 Perform the following actions:
1.  Create a new project for the STM32L496ZGT6.
2. On the Clock Configuration tab, MSI RC is the default clock signal source.
3.  On the Pinout & Configuration tab, within the RCC group, the MSI Autocalibration option is available but cannot be enabled. This makes sense, as the Low Speed ​​Clock (LSE) is disabled.
4.  When I configure LSE, the MSI Auto Calibration option disappears.
Am I doing something wrong?
gbm
Sep 16, 2026 08:41 UTC
Reproduced. Previously I started from Nucleo-L496 board and it was ok. If you start with the chip, the problem appears.
Ghofrane GSOURI
THX
Ghofrane
