Jun 11, 2025 10:25 AM UTC
STM32H7RS+FreeRTOS+USB HOST+FatFs Can't Enable USBH_USE_OS
Hello:
  I wasn't able to enable support for RTOS in USB_HOST menu in CubeMX_6.14.0 for STM32H7R3I8Kx. There is only "Disabled"
  The version of STM32Cube MCU Package for STM32H7RS Series is 1.2.0
FBLBest answer
Jun 11, 2025 10:59 AM UTC
Hello @miku
An internal ticket (211979) is submitted to dedicated team to fix this issue.
Manually setting #define USBH_USE_OS 1U in the usbh_conf.h file should resolve the issue.
FBLBest answer
Hello @miku
mikuAuthor
Jun 12, 2025 5:49 AM UTC
Thank you for your reply.
