kulfi27
Nov 29, 2019 9:32 AM UTC
STM32H753 change frequency in the older version to 480MHz
Hello everyone, at the beginning of this year I bought a microcontroller, it was a version with 400MHz clocking, at the moment CubeMX allows you to change the frequency to 480MHz, can I change it, will everything work properly. Best Regards
PMath.4
Senior III
Nov 29, 2019 9:45 AM UTC
I've got 400MHz spec H743's running at 540MHz with no issue including running FMC, LTDC and USB peripherals
Ozone
Principal
Nov 29, 2019 10:40 AM UTC
The maximal core clock speed specified in the datasheet is guaranteed for the whole temerature range, especially the maximum temperature.
Expect fails (crashes) at higher temerature with overclocked devices.
kulfi27
kulfi27Author
Nov 29, 2019 1:52 PM UTC
Thank you for the quick reply, I will take this into account.
