dns13
Mar 29, 2022 9:21 AM UTC
STM32H7 - CubeMX 6.5.0 + LwIP + mbedTLS Lwip is disabled as FreeRTOS is not detected
When I migrate my Project to CubeMX 6.5.0 LwIP gets disabled and cannot longer be enabled as long as mbedTLS is enabled. FreeRTOS is enabled and this configuration worked fine with CubeMX 6.4.0.
I tried to cycle all relevant settings, switched cores but haven't found a way to get both mbedTLS and LwIP to be enabled.
How can I fix this?
Sara BEN HADJ YAHYA
Apr 8, 2022 10:33 AM UTC
Hello @Jan Schöppach​
You are right, issue confirmed from my side. It seems that the LwIP and MbedTLS cannot be enabled simultaneous in v6.5.0.
For now I advise you to keep using v6.4.0 until the issue gets fixed.
With this being said, I submitted a ticket to dev team to fix this issue. I will keep you posted :)
Internal ticket number: 126096 (This is an internal tracking number and is not accessible or usable by customers).
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Thanks for your contribution and sorry for the inconveniences,
Sara.
Mar 30, 2022 8:39 PM UTC
Hello @Jan Schöppach​ ,
First let me welcome you to the STM32 Community and thank you for reporting this issue.
I share your post with STM32CubeMX team @Sara BEN HADJ YAHYA​ to review this issue and take the necessary action.
Imen
dns13
dns13Author
Mar 31, 2022 6:51 AM UTC
Thank you
Sara BEN HADJ YAHYA
Apr 8, 2022 7:33 AM UTC
Thanks for your feedback,
Just to make sure that I understood correctly your issue. Are you asking for a way to enable LWIP and MbedTLS simultaneous without the need to enable FreeRTOS ?
Please correct me if I'm wrong.
And could you please share your ioc file before project migration ?
Thanks,
Sara.
dns13
dns13Author
Apr 8, 2022 7:39 AM UTC
Hello Sara,
no I want to enable all three, but as soon as I enable MbedTLS it does no longer allow me to enable LWIP either with FreeRTOS enabled or disabled. This worked fine in 6.4.0.
Jan
Sara BEN HADJ YAHYA
Sara.
dns13
dns13Author
Apr 8, 2022 10:35 AM UTC
Thank you, Sara.
Will stick to 6.4.0 by now.
Greetings
Jan
Sara BEN HADJ YAHYA
Jun 29, 2022 11:47 AM UTC
This issue is fixed in STM32CubeMX latest release.
V6.6.0 is now available under this Link.
Thanks for your contribution.
Sara.
