DBroo.1
Sep 11, 2019 10:18 PM UTC
STM32CubeMX V5.3.0 does not generate correct code for SystemClock_Config()
Anyone aware of this problem and any workaround, other than manually changing the generated file? Specifically, ​ RCC_OscInitStruct.PLL.PLLR,  RCC_OscInitStruct.PLL.PLLP and
 RCC_OscInitStruct.PLL.PLLR are not being configured correctly, causing the first call to HAL_GetTick() inside HAL_RCC_OscConfig() to crash.
Sep 12, 2019 12:39 AM UTC
For what STM32 part? Trying to narrow this down a bit.
Make sure SystemClock_Config() zeros out the local/auto variable.
DBroo.1
DBroo.1Author
Sep 12, 2019 1:07 PM UTC
​Sorry Clive. It's the STM32G070CB. And to be more specific, these parameters were configured on the Clock Configuration Tab in Cube as:
RCC_OscInitStruct.PLL.PLLN = 9
RCC_OscInitStruct.PLL.PLLP = 3
RCC_OscInitStruct.PLL.PLLR  = 3,
but the code generated:
RCC_OscInitStruct.PLL.PLLN = 8
RCC_OscInitStruct.PLL.PLLP = 2
RCC_OscInitStruct.PLL.PLLR = 2.
HOWEVER, in trying to pull this information together for you this morning, Cube generated the correct code this time. ??? I have been quite careful to save the project before generating code, but "Generate Code" saves the project anyway. So, I am not sure what is going on.
DBroo.1
DBroo.1Author
Sep 25, 2019 2:24 PM UTC
​Resolved
