wuio
Jan 21, 2019 9:13 AM UTC
STM32CubeMX V5.0.1: error in uwTimclock with STM32G0xx (with Timebase source TIM15, TIM16, TIM17)
If, as the basis of time, I use a different timer than the systick in the hal_timebase_tim file in the ruler
 uwTimclock = HAL_RCC_GetPCLK2Freq ();
there is an error. Should
 uwTimclock = HAL_RCC_GetPCLK1Freq ();
WBOUGBest answer
Jan 24, 2019 9:15 AM UTC
Hi @wuio​
Your issue has been transmitted for the dev team.
it will be implemented in the next version of the CubeMX.
Best Regards,
Wael
Jan 21, 2019 3:23 PM UTC
Hello @wuio​ ,
Can you please share your ioc file to check this issue.
I cannot reproduce your issue, I checked from my side and I have:
 uwTimclock = HAL_RCC_GetPCLK1Freq();
Kind Regards,
Imen
wuio
wuioAuthor
Jan 22, 2019 10:32 AM UTC
It depends on which timer you choose as the basis of the system time. I chose tim17 but when I chose tim 6 it was ok.
Jan 22, 2019 2:13 PM UTC
Hi @wuio​ ,
You are right, I raised this issue internally to CubeMX team for fix.
Thanks for your contribution.
Kind Regards,
Imen
WBOUGBest answer
Hi @wuio​
Best Regards,
Wael
