kurta999
Senior
Sep 12, 2018 6:19 AM UTC
STM32CubeMX v4.27.0 Do not generate main() doesn't set in GUI, when re-opening project file
I opened a project, upgraded to new CubeMX. Checked this option, regenerated the project. After re-opening the CubeMX file, this option is still set, because generation work correctly (no main() generated), but GUI isn't show it as set. The "set" sign (idk what is proper name for this :)) is missing.
After opening settings tab, clicking on OK will result in re-generating main().
Khouloud GARSI
Sep 12, 2018 11:28 AM UTC
Hi @kurta999​ ,
This is reported internally for further check.
Sorry for any inconvenience this may have caused.
Khouloud.
Houda GHABRI
Oct 9, 2018 3:46 PM UTC
Hello @kurta999​ ,
Sorry for the late response.
I'm not able to reproduce the issue with STM32CubeMX v4.27.0 (migrated from 4.26.1).
Could you please send me the ioc.
Regards,
Houda
kurta999
kurta999Author
Senior
Jan 9, 2019 2:31 PM UTC
It's still bugged in 5.0.1, sadly.
kurta999
kurta999Author
Senior
Feb 26, 2019 8:03 PM UTC
Is this bug planned to be fixed in near futire? Tested with 5.1.0, sadly still nothing changed.
kurta999
kurta999Author
Senior
Feb 26, 2019 8:04 PM UTC
Khouloud ZEMMELI
Feb 27, 2019 3:16 PM UTC
​Hello @kurta999​
Sorry for the delay in answering,
I have reported this issue and it will be fixed in the next CubeMX release.
Sorry again and thank you for the feedback.
Best Regards,
Khouloud.
kurta999
kurta999Author
Senior
Feb 27, 2019 6:52 PM UTC
Thank you!
kurta999
kurta999Author
Senior
Apr 28, 2019 11:08 AM UTC
Is this bug planned to be fixed in near future? Tested with CubeMX 5.2.0, same behaviour as before. Nothing changed.
