chriskuku
Senior II
June 20, 2022
STM32CubeMX permission problem /Users under macOS 11.6.6.
I installed STM32CubeMX under macOS (11.6.6). When I click "about STM32CubMX" a box pops up:
java
Version 1.0 (11.0.10)
When I click "Generate code" I'm getting a box saying "/Users: permission denied"
SamHansen42
any luck? same issue
December 6, 2023
Ran into the exact same issue and was able to fix it by not using `/home` in the project location. macOS does not play well with `/home` so ensure you use `/Users/[YOUR USERNAME]` as the project location in the Project Manager tab.
Note you may have to start a new project as my existing project's path was greyed out after it attempted to generate code.
August 30, 2024
Ran into the same issue as well and it worked for me under ´/users/[YOUR USERNAME]/anotherdirectory`.
