magnus_lindhe
STM32CubeMX install on Ubuntu 22.04: "Error executing /bin/chmod"
I am trying to install STM32CubeMX-6.10.0 on Ubuntu 22.04.
Following the instructions, I have unzipped the installation ZIP archive and changed the permissions for SetupSTM32CubeMX-6.10.0 to be executable. I have also made all files in jre/bin/ executable.
I then run SetupSTM32CubeMX-6.10.0 from my home directory and pick an installation directory in my home folder, but during step 1/7 of the installation, it fails with an error:
"Error executing /bin/chmod a+x /home/magnusl/STM32CubeMX/STM32CubeMX"
I have tried running the installation as sudo and I get the same error. I have also tried to manually run
and it works fine. But if I restart the installation script after this, it complains that STM32CubeMX is already running, so I cannot make it continue unless I delete the whole directory and then I'm back on square 0.
Does anyone have an idea on how to solve or work around this problem?
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello @magnus_lindhe
First let me thank you for posting.
To resolve the issue you are facing during the installation of STM32CubeMX-6.10.0 on Ubuntu 22.04 you can follow these steps:
1- Delete the directory where STM32CubeMX was installed.
2- Restart the installation process from scratch.
3- When prompted to choose an installation directory, select a different location to avoid conflicts with the previous installation attempt.
By deleting the directory and choosing a new installation location, you should be able to proceed with the installation without encountering the error related to /bin/chmod
THX
Ghofrane
Ghofrane GSOURI
THX
Ghofrane
