Hiroshi Sakurai
Mar 24, 2017 6:28 AM UTC
STM32CubeMX ignores ''Uses FreeRTOS functions'' checkbox
Posted on March 24, 2017 at 07:28
I'm trying to make a interrupt handler which doesn't use FreeRTOS function and preemption priority is higher than FreeRTOS, say 2.
However every time I load .ioc file, STM32CubeMX checks the 'Uses FreeRTOS functions' checkbox of the interrupt handler, so I need to uncheck it manually.
Please try with the attached .ioc file.
STM32CubeMX version is 4.20.0
STM32Cube FW_F7 V1.4.1
#stm32cubemx
Mar 24, 2017 12:36 PM UTC
Posted on March 24, 2017 at 13:36
Your issue is reported internally to our CubeMx team for further check.
You should use the last version of STM32CubeF7 firmware package which contains fix defect, enhancements and updates to new version of FreeRTOS V9.0.0
Imen
Jeanne Joly
Apr 27, 2017 1:00 PM UTC
Posted on April 27, 2017 at 15:00
Hi
Sakurai.Hiroshi
For your information, the issue you reported will be delivered in the next CubeMX release (4.21).
BR. Eric
