Mar 28, 2017 11:05 AM UTC
STM32CubeMX How to add other middlewares
Posted on March 28, 2017 at 13:05
Can I add Middlewares from X-Nucleo in STM32Cube MX ?
#stm32cubemx
Mar 28, 2017 11:09 AM UTC
Posted on March 28, 2017 at 13:09
You may refer to the
http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM00104712.pdf/files/DM00104712.pdf/jcr:content/translations/en.DM00104712.pdf
user manual, it will help you for STM32 configuration in the
S
TM32CubeMX
Imen
4316139955
Mar 28, 2017 1:53 PM UTC
Posted on March 28, 2017 at 13:53
The UM1718 is how to install and use STM32CubeMX and Processor Library, not how to add X-Nucleo MiddleWare.
Example : How can I add Bluetooth or Wifi or Mics X-Nucleo cards on a new STM32CubeMX project.
Marc
Mar 28, 2017 4:26 PM UTC
Posted on March 28, 2017 at 16:26
This
is not supported by STM32CubeMX code generation tool.
So, you will have to manually add it to your project.
I will raise your feedback internally to our CubeMx team.
Imen
Sirma Siang
Aug 25, 2017 9:24 AM UTC
Posted on August 25, 2017 at 11:24
Hellol
Marc.Voss
I would like to thank you for your suggestion.
Actually the subject you raise is complex. It is link to board stacking, and the way to generate the code, including the one for the stacked HW, for a particular config.
This subject is under study, but will take a significant amout of work.
Let's monitor it.
Kind regards
Sirma
Peter Gibbons
Feb 13, 2018 3:27 PM UTC
Posted on February 13, 2018 at 16:27
I agree. The software packages being such a big component of the stm32cube tool, it surprised me that none of the manuals explained how to install them.
