BSpoe.1
Mar 5, 2020 6:56 AM UTC
STM32CubeMX Code Generation for STM32CubeIDE without linking library files
why it's not possible to copy all neccessary library files to my generated project for CubeIDE?
When I choose EWARM, then this is possible...
Thanks a lot,
Ben
Khouloud ZEMMELI
Khouloud ZEMMELIBest answer
Mar 5, 2020 7:05 AM UTC
​Hello @Community member​ ,
You need to Uncheck the "Generate Under Root" first then you will have access to all options.
Best Regards,
Khouloud
Khouloud ZEMMELI
Best Regards,
Khouloud
BSpoe.1
BSpoe.1Author
Mar 5, 2020 7:07 AM UTC
Thanks, this works!
Khouloud ZEMMELI
Mar 5, 2020 7:08 AM UTC
(Only the "Copy all used.." ​is grayed in your case, if you have a problem in other options thanks for telling me).
