PCast.2
Oct 8, 2021 11:27 AM UTC
STM32CubeMX Clock Configuration not generating any code for LSCO Source Mux
When selecting LSI as output for LSCO pin, and generating code with integrated STM32CubeMX, no output is seen on LSCO pin.
0693W00000FBt0wQAD.pngI have to manually add a call to this to see LSI on LSCO pin.
HAL_RCCEx_EnableLSCO(RCC_LSCOSOURCE_LSI);
When using MCO pin instead of LSCO pin, the code for source clock selection is generated correctly.
I'm using STM32CubeIDE v1.7.0. and STM32L432KCU MCU.
Thanks and kind regards,
Pedro.
Sara BEN HADJ YAHYA
Nov 29, 2021 10:35 AM UTC
Hello @PCast.2​ ,
This issue is fixed in the latest release of STM32CubeMX ( version 6.4.0 available on https://www.st.com/en/development-tools/stm32cubemx.html).
Thanks for your contribution.
When your question is answered, please close this topic by choosing Select as Best.
Regards,
Sara.
Sara BEN HADJ YAHYA
Oct 26, 2021 1:29 PM UTC
Which STM32CubeMX version are you using?
Best Regards,
Sara
PCast.2
PCast.2Author
Oct 26, 2021 1:41 PM UTC
Hi Sara,
This is the info about STM32CubeMx version I found in .ioc file:
MxCube.Version=6.3.0
MxDb.Version=DB.6.0.30
ProjectManager.FirmwarePackage=STM32Cube FW_L4 V1.17.0
Best regards,
Pedro.
Sara BEN HADJ YAHYA
Oct 26, 2021 1:45 PM UTC
Hello again,
Could you please share with us your .ioc file?
Thanks in advance,
Sara.
PCast.2
PCast.2Author
Oct 26, 2021 1:52 PM UTC
Hello Sara,
Attached to this post you can find it.
Regards,
Pedro.
Sara BEN HADJ YAHYA
Oct 27, 2021 10:55 AM UTC
Hi @PCast.2​ ,
Thanks for your feedback,
You are right, It seems that the STM32CubeMX does not generate the code to enable LSCO output, for now you have to add HAL_RCCEx_EnableLSCO(RCC_LSCOSOURCE_LSI); manually.
Your request have been reported internally, I'll keep you posted with the updates.
Sara.
PCast.2
PCast.2Author
Oct 27, 2021 11:21 AM UTC
Thank you Sara!
Sara BEN HADJ YAHYA
Hello @PCast.2​ ,
Regards,
Sara.
