YZhao.4
Dec 1, 2022 1:38 PM UTC
STM32CUBEMX can not be opened when connecting the network.
If I open cubemx using the terminal., I can find log messsge like: ThirdPartyUpdaterWithRetryManager:70 - Updater plugin not ready yet. [12/15].
Finally, cubemx reports IntegrityCheckThread:98 - exiting critical section [integrity check]. And It was stuck on the cover of cubemx.
PS: I using Apple M1 Pro on macos 13.0.1 (22A400)
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Dec 5, 2022 8:54 AM UTC
Hello @YZhao.4​
First let me thank you for posting.
Let's try this solution: Uninstalling CubeMX and reinstalling it again
According to the STM32CubeMX USER Manual :
Uninstalling STM32CubeMX on macOS® There are two different ways to uninstall STM32CubeMX on Mac:
1. Move STM32CubeMX.VERSION.app to the trash
2. Use the following command line: a) For STM32CubeMX 6.2.x and later versions only:
cd SetupSTM32CubeMX-VERSION.app/Contents/Resources/Uninstaller ./uninstall.sh
b) For STM32CubeMX 6.1.x and older versions only:
java -jar SetupSTM32CubeMXVERSION.app/Contents/Resources/Uninstaller/uninstaller.jar
Installing STM32CubeMX on macOS®
To install STM32CubeMX, make sure you have administrator rights and then:
1. From an Internet browser, open the page www.st.com/stm32cubemx
2. Click “Get Software�? to go to the software download section
On macOS:
a) On STM32CubeMX-Mac line, Click “Get software�? to download the package
b) Extract (unzip) the downloaded package.
c) Make sure you have administrator rights.
d) Double-click SetupSTM32CubeMX-VERSION.app application file to launch the installation wizard.
In case of error, try to fix it: - $sudo xattr -cr ~/SetupSTM32CubeMX-VERSION.app.
Please try this solution and do not hesitate to raise any issues or feedback.
Thx
Ghofrane
Ghofrane GSOURI
Hello @YZhao.4​
On macOS:
Thx
Ghofrane
YZhao.4
YZhao.4Author
Dec 5, 2022 5:16 PM UTC
Thanks for your solution!
I use ​./uninstall.sh to uninstall cubemx included java and .cubemx files. Then I reinstall stm32cubemx on my mac.
The problem was fixed. I can open stm32cubemx successfully with network connection.
