martonmiklos
Senior
Nov 22, 2018 9:30 AM UTC
[STM32CubeMX bug] Cancelling the migration dialog removes the project from the recent projects list
Title says almost all:
I have had a project which needs support package migration. I hit cancel and the project disappeared from the home screen and the File -> recent projects menu as well.
I am using 5.0.0 version on Linux
Nov 22, 2018 12:49 PM UTC
Hello @martonmiklos​ ,
Which STM32CubeMx version is used?
Can you please share your ioc file to check your case.
Kind Regards,
Imen
martonmiklos
Senior
Nov 22, 2018 12:54 PM UTC
Hi @Imen DAHMEN​
I am using 5.0.0 on Linux, but it happens on OSX as well according to my colleauge.
I have sent the ioc file to you via e-mail. Please let me know if you have not received it!
Nov 22, 2018 1:08 PM UTC
Thank you for sharing your ioc file. This will help our CubeMX team to check and reproduce the case.
We will keep you informed about the taken actions or explanation if needed.
Kind Regards,
Imen.
Houda GHABRI
Nov 22, 2018 2:19 PM UTC
Thanks for your feedback.
If you want to continue without migration you should press continue and not cancel.
it is normal that project disappear if you press cancel.
plz feel free to contact me for further details.
regards,
Houda
martonmiklos
Senior
Nov 22, 2018 2:46 PM UTC
I still think it should not be removed from recent.
i think you handle the following two scenarios the same:
  • If I open an ioc which is not in the recent list and I press cancel it should not add to the recent list.
  • But if I open an file which is already in the list and hit cancel it should not be removed.
Houda GHABRI
Nov 22, 2018 3:41 PM UTC
"Recent" is for recent opened project.
When you press cancel before starting project it is not considered as opened that's why it is not available on recent files.
Regards,
Houda
