HMcKi
Jul 3, 2019 2:18 AM UTC
STM32CubeMX and Keil MDK integration
Hi Guys,
The latest version of STM32CubeMX allows me to use firmware packages for the F7 architecture versions 1.13.0 and 1.14.0. The latest version of the Keil STM32F7xx_DFP 2.11.0 (2018-09-05) says it uses firmware package version 1.12.0.
Unfortunately I have projects using a range of firmware versions. Is there some sort of strategy or recommendation to managing this?
This has arisen because Keil's networkInitialize causes a hardfault on DFP version 2.10.0 and 2.11.0, but works fine on 2.9.0. I was trying to make sure the code Cubemx was generating was 'as close to perfect' as possible. Any comments on this issue would also be appreciated.
Cheers,
Hamish.
